H22A
By mooze
#243845 the mounts should change nothing
By Eg6H2D
#244929 What driver side mount did you use?
By mooze
#245080 thats the one u have to make a bracket to bolt to the motor...i had a set of eg h22 mounts so i used the drivers mount and i made a bracket to fit the block. u can use a mount from any motor into the eg...u just have to make the bracket to fit the mount....if u can find a b series mount it should make it a little easier
By Eg6H2D
#245257
mooze wrote:thats the one u have to make a bracket to bolt to the motor...i had a set of eg h22 mounts so i used the drivers mount and i made a bracket to fit the block. u can use a mount from any motor into the eg...u just have to make the bracket to fit the mount....if u can find a b series mount it should make it a little easier
Gotcha. right now i have innovative B/D series 3 bolt mount kit. so my driver side mount is the "GSR" or ABS driver 3 bolt mount. .. So that should make it easier?
I just been doing alot of thinking about the H2B mounts. Since it's the same concept would they fit H2B and H2D. The mounts i have now i can use for a B swap and everything will line up properly. IM wondering if that same concept applies if i were to use the H2B mounts for this H2D set up. which i can actually get through hasport.. . Dont know til i try right?
By mooze
#245363 again its not the mounts that u have to worry about.....forget the mounts and worry about what ur going to be bolting the mount to.....THE BRACKET THATS BOLTED TO THE BLOCK IS THE KEY
By Eg6H2D
#245482
mooze wrote:again its not the mounts that u have to worry about.....forget the mounts and worry about what ur going to be bolting the mount to.....THE BRACKET THATS BOLTED TO THE BLOCK IS THE KEY
I knoww.. i knowww. lol. it was just a thought..
By mooze
#262743 so as most of you know i had to take a break from my civic as i was deployed................but now im back...so i started the fresh build today....will have pix uploaded a little later
By Eg6H2D
#262869
mooze wrote:so as most of you know i had to take a break from my civic as i was deployed................but now im back...so i started the fresh build today....will have pix uploaded a little later
HOLY SHIT!!!! welcome back sonnnnnnnnn!!!
check out my updates!! :thumb:
By mooze
#267892 Image
By mooze
#267999 yeah its gettin there
By mooze
#268048 For those who were curious before
By Eg6H2D
#268054
mooze wrote:For those who were curious before
!! lol.. I have not seen that yet!! Nice though!!! is it a good fit into the bay? you moving the Radiator? :thumb: :woot: :thumb:
By mooze
#268057 Fits fine. Slim fan on radiator and condenser. Keep ac with boost. That's a bad azz mani
