By djustice_tn
#101262 i have a 93 si civic hatch with a jdm B16a swap and it seems like everytime i hit the brakes theres a popping noise...anyone know what that could be?
By hondajunkee
#101265 could be kinda a dumb response, but have you checked that your lug nuts are tight? I had a loud pop sound when i would break, come to find out the lug nuts were loose
By foru2nvy2
#101272 yeah i had the same thing happen to me,i couldnt figure it the tire ended flying off ,while my wife was driving ,some funny shit she freaked out,if there aluminum wheels check them often,they shrink and expand and the lug nuts work themselves loose
By djustice_tn
#101379 k ill check the wheels n lug nuts tomorrow...i figured it might be somethin with the slave cylinder or brake lines or somethin but all replys are appreciated ill sure check em out....thx
By foru2nvy2
#101380 heres a pic of what happened to my old car when i couldnt figure why it made so much noise it broke lug nut off to i know its a chevy
By djustice_tn
#101547 welp checked out the car today and the wheels look fine,all the lug nuts are tight,and the brake fluid resivor is full...and the popping sounds like its getting worse than it used to be. any other suggestions?
By blockustomz
#101548 take the wheels off and inspect the rotors pads cailpers drums slave cylinders. everything..
By djustice_tn
#101634 yea looks like thats the next step
By djustice_tn
#102656 i took the wheels off and inspected everything and all looks normal,but now it seems like it only pops if i push the brake fast like a sudden stop....if i slowly push the break in like preparing to stop at a red light it dosent do it at all...i dont know what it could be
By Gunni
#103092 a bad front lca bushing can make that sound..
nr 9 and 14
By Sire
#106257 Maybe you're missing one of the brakepad clips (for lack of a better word) in your caliper? Could be that your pads are sliding back and forth... :?
By suspendedHatch
#106286 Yeah it's a bad bushing or ball joint. And the bushings will look fine mounted to the car so you have to remove your LCA's to inspect them. This is exactly what I'm dealing with on my wife's 01 Civic. It's a 2001 and already both front LCA bushings are shot, both front lower ball joint boots are torn, the end links need to be replaced, and the front engine mount is ripped (lucky she has me to save her $$$). So just imagine what shape your car is in being that it's 6-9 years older! Because I know these cars so well I can already guarantee you that both your rear trailing arm main bushings need replacing and both your front lower engine mounts are completely gone.
