By eg4
#75938 I just wanted to know if there is any particular setup when you lower your car. Should the front and back be on the same level or keep the back a little bit higher than the front or vice versa, And whats the best height for a 15" rims.
By Graham
#75939 If you have coilovers just adjust them till you're happy, i had mine set to the same drop all round but having the back slightly higher looks good too - please dont have the back lower than the front!!!
By Civic_HatchSI
#75945 Its hard to get them to be all the same, I have adjusted mine a lot and Im still not happy with the stance lol. Either my front is to high or the back is too low that it rubs. Just set it to your liking and try to get it equal :thumb:
#75948 I have springs that are supposed to set an equal rate all around, but one side sits a little lower. it's never equal really lol
By eg4
#75994 I have adjustable springs I am quite happy with them but the car bounces alot and I thought that I have a bad setup, They are hard so it suppose to bounce a little bit but my friend has the same and the ride is better then mine and I thought I was doing something wrong. There isn't any particular height to keep between the back and front because I want to keep the front a little bit lower than the back or its all about what you like?
