By Sentry
#132421 I thought you didn't need a tie bar if you had a subframe brace. :?
By egsedanguy
#132427
Sentry wrote:I thought you didn't need a tie bar if you had a subframe brace. :?
there is no need for it. its just a bling factor then. that subframe brace is 100x stronger than any lil tie bar. but it does look hella sick with both on there..
#132439 It should be an easy install 8)
By Carfanatic
#132486 oke good 8)
Yes, it is just the bling factor with a beaks bar under it :oops: but i like it alot!!
thnx
By Civic_HatchSI
#132541 very easy install, I wanted the beaks bar also with my subframe but I cant seem to find one :thumbdown:
#132569 Nice!! :thumb:
By Vti93T
#132709
Civic_HatchSI wrote:very easy install, I wanted the beaks bar also with my subframe but I cant seem to find one :thumbdown:
www.jhpusa.com has one.
