By blk92hb
#182411 ok so today i was driving along and noticed i had about 1/2 of steering play in the steering wheel. could that be due to a bad wheel bearing or outer tie rod
#182425 Yes check your inner/outer tie rod. grab the sides of the wheel and try to turn it toward/away from you. If it has play then it is either wheel bearing or tie rod. Next try to wiggle the wheel but wiggle from top to bottom. if it wiggles that way then it is the wheel bearing. tie rod end will wiggle left to right. wheel bearing will wiggle every direction.
By blk92hb
#182517 ok thanks i know its not the inner tie rods i had to replace them both for inspection. do i have to jack the car up or can i leave it on the ground
By blk92hb
#182728 i checked it today and its my outer tie rod on the driver side so i hope thats it
