By 3kkl3sia
#184849 When i lowered my car, i was told something will give way eventually.
Well, soon after i did i started noticing when i turned left when backing up there was a slight clicking noise, didn't think anything of it. Then it happened ONLY on cold mornings turning left but went away after about 5mph. Now it does it both ways, and going straight you can hear it. If it is cold/raining out that effects it and the car randomly pulls me to the right so bad i have to hold on with both hands and it makes a horrible noise. But only does it for a second or 2, as soon as i turn fast and even change gears it stops for a while. Like i said, only happens when its cold and wet outside...any suggestions will help.
By Carfanatic
#184868 definitely a cv joint
teal_dx wrote:sounds like worn CV joints to me
x2
By 3kkl3sia
#184895 Well i took it over to johns and got it all fixed. It was my axle, the boot was completly ripped and water got into the axle greese, there is the old one
