- Mon Apr 05, 2010 10:24 pm
#185738
What is a better choice? What gives you a better ride? Adjustable coil overs or drop springs?
- Wed Apr 07, 2010 8:36 pm
#186142
It all depends on personal preference really. I will never own springs but my bf says they ride better..However, they don't go as low as you can on coilovers. I like coilovers because you can slam the car one day and raise it up the next. Springs you are stuck with whatever size you get.
- Thu Apr 08, 2010 12:35 am
#186222
But if you are going to drive around, you will want to get it aligned after changing the ride height or say goodbye to your tires.
I prefer coilovers because if your car is lightened a lot, then you can go a little lower to compensate. With springs, you're stuck at a higher ride height.
Vti93T wrote: I like coilovers because you can slam the car one day and raise it up the next.
- Thu Apr 08, 2010 11:14 pm
#186503
id say function fourm type 1's there farly cheap and really good from what i herd, im actually savin up for a set.. there around 700 everywhere i look
but thats my personal opinion, others might say diff, but its up to you if u want full coilovers or a diff pair of sleeves..
there is skunk2, tein, eibach, megan racing, or the knock off brand
- Thu Apr 08, 2010 11:35 pm
#186504
at Weksos they are $630 with free LCAs. http://www.weaksauceparts.com/store/home.php?cat=958
- Fri Apr 09, 2010 1:35 pm
#186586
Not as much as you might think. Lowering and raising the car will change the camber angle but that doesn't kill tires as fast as the toe angle being out ... that's what will chew the shit out of your tires.
Camber will cause slightly uneven wear, toe will cause you to have 2" or so of your tire bald and the rest looking just fine.
teal_dx wrote:Vti93T wrote: I like coilovers because you can slam the car one day and raise it up the next.
Straight lines are for sissies.
- Wed Apr 28, 2010 12:01 am
#190507
From what I've heard, if you want drop springs get the Eibach sportlines, they have a nice ride and will work fine with stock dampers. Or you can mate them with a midgrade damper of some sort. The ride is supposed to be really nice.
- Thu Apr 29, 2010 11:43 pm
#191060
Lowering spring will not give you that "slammed" look. To get that you need to get adjustable coils, come to think of it I don't think I've ever seen pics of drop springs even tucking the wheels.
