Swapping suspension from Del sol to Coupe
I'm going to attempt to swap the front and rear suspension off of my B16 del sol onto my coupe. I have KYB AGX's and Skunk2 coilovers. I wanted to swap the entire setup onto my coupe, including the Sel sol's rear disk brakes. How is the swap going to be different from this?
http://civic-eg.com/viewtopic.php?t=4129
I also wanted to swap the front hub assemblies as well, since the ones on my coupe have bad wheel bearings. PULEEEEEEAAAASE help. I've never attempted suspension work on my own before. The most I've done is swap axles. (My axle pops out at least twice a week on my type r swap.)
I also would like to swap the del sol's larger sway bars too. I miss the way the del sol handled.
