- Thu Sep 29, 2011 4:45 pm
#275267
Hey guys a few weeks ago I change most of my steering and suspension parts; struts, balljoints, upper control arms and outer tie rods...evrything felt good but a couple of days ago I began getting a rumbling shaking sound comin from d front left wheel over minor and major road bumps the steering wheel will also vibrate and pull to the left when this happens.....what could it be ..cv joints, wheel bearings and inner tie rods were not changed...my car is RHD by the way
- Thu Sep 29, 2011 8:31 pm
#275294
it only does it over bumps only or all the time can you hear and get the vibration. And this might be a dumb question but you replaced everything with new parts correct?
Could be a wheel bearing but that should make noise all the time. Sounds like possible a strut or your rack has got some sort of issue. Possibly even one of the ball joints that you replaced was defective from the factory and has already blown out. Might need to take the wheel off and have a look to make sure but the CV shaft should not cause that.
