whats out there, i need aftermarket trailing arm bushings ?
Sat Oct 15, 2011 3:09 am
by elrompetoto
ok so its that time i need 2 replace my trailing arm bushings
1.im looking 2 spend no more then 100 bucks
2.the stiffer the better
so guys give me brands so i can start reading up on them
thanks
Sat Oct 15, 2011 3:27 am
by JUICE
I'd usually recommend Energy Suspension for any aftermarket bushing.. I personally put in OEM when i did my rear disc swap..
but this guy says..
danomatic93 wrote:the TA bushings are the only bushing that you don't want to be the ES ones. The Civic's TA bushings are designed for flex when you corner. If you installed the solid ES bushings, you would no longer get that flex in there. That is only desired if you were driving a drag strip car.
then this guy says..
Mordiiax wrote:ES trailingarm bushing is rubbish. Go with CR-V bushing instead (part #: 52385-SR3-003), it is stiffer then Civic oem. 1mm bigger but that is no big deal, just clean the area where it goes before you install it Smile A lot cheaper then the Mugen dito.
Sat Oct 15, 2011 3:30 am
by elrompetoto
thats the problem im runing into so much pplz saying diff things
Sat Oct 15, 2011 3:35 am
by RWMIII
I agree with the CR-V upgrade personally for a cheap oem upgrade. But also like poly alot too. Ultimate choice would be poly.
Sat Oct 15, 2011 3:56 am
by EJ1_MK
yeah you either go with factor, the CR-V upgrade or you do a poly bushing or a spherical bushing.
Really in the fact that if that is the only bushing that is poly you might not notice it being that stiff. I run the Hardrace and hard to tell since I replaced all the suspension at the same time.
Sat Oct 15, 2011 2:52 pm
by bks84
I too use the Hardrace bushings throughout. I recommend those.
"stiffer" is not always "better"... fyi
Sun Oct 16, 2011 3:43 pm
by elrompetoto
k so ill look into hard race
Sun Oct 16, 2011 4:17 pm
by Fada Blayne
i got Hardrace. no complaints
