- Tue Mar 31, 2009 11:14 pm
#106989
When putting an ITR rack into an eg, do you use the power steering hoses from the ITR or do you use your standard eg ones?
I know you can use the standard eg hose on the passenger side of the rack and that it connects straight up, but the hose that goes from the drivers side bit on the rack to the top of the PAS pump im not sure about...
One of the lines on my eg rack is seized solid so theres no way ill get it off without messing up the nut, will need to get another one but unsure if i need an eg one or one from an Integra...
Anyone shed some light on this?
