Graham wrote:Im getting confused with you guys inch's
I may be talking rubbish but i was sure that 98 spec integras had 282mm brakes....
Ill try and find out
from what I know, all 94-01 USDM integras are 262mm minus the Type R which is 282mm.
B16nintyfiveCoupe wrote:it's easier if u just get the whole knuckle..
LowTEC-Derbo wrote:Graham wrote:Im getting confused with you guys inch's
Graham wrote:B16nintyfiveCoupe wrote:it's easier if u just get the whole knuckle..
wtf is a knuckle
vtec_gloucester wrote:^^^ your right, 98 spec ITR's have 282mm's
LowTEC-Derbo wrote:vtec_gloucester wrote:^^^ your right, 98 spec ITR's have 282mm's
From the looks of what you are telling us, you will probably have everything. Just make sure the wheel bearings are good on all 4 ends before slapping them in. last thing you want to do is get wheel bearing fix on the car.
Gorveatt wrote:LowTEC-Derbo wrote:vtec_gloucester wrote:^^^ your right, 98 spec ITR's have 282mm's
+a billion, bad bearing ftl, i've had to replace both front ones, and need to replace a rear one soon
