- Mon Mar 22, 2010 8:28 pm
#182921
I recently acquired a 95 EG Hatch and I am looking to take it to some lapping days this summer. I was wondering what would be a decent brake upgrade while staying 4 lug.
- Mon Mar 22, 2010 10:34 pm
#182960
integra ls is a good one. it 4 lug and bolt directly in. just need the proportioning valve
- Tue Mar 23, 2010 12:27 am
#182992
What is the advantage brakes over the stock ones? I am assuming bigger rotors and possible more clamping force?
- Tue Mar 23, 2010 7:35 pm
#183185
yup purty much. but intalling the rear is the big plus since only some eg models came with rear disk. over the stock civic front rotors and rear drums, you will have a lager front rotor and bigger caliper with more force and the rear will be a disk witch everyone knows is much better than a drum. plus its all bolt in with no mods. plus you can find a full set with everything for like 350-500$ if you do decide to remeber you need the propotioning valve and the ls integra e-brake cabel.
- Wed Mar 24, 2010 7:23 pm
#183466
yup purdy much
- Wed Mar 24, 2010 7:28 pm
#183469
I am also debating just throwing a Willwood kit on the front and calling it a day.
- Thu Mar 25, 2010 7:11 pm
#183689
you could but then i would sudjest you convert the rear to ls disk. otherwise your gonna have lot of clamp power in the front. i know you want it to be more stoping power in the front but i think to much will cause to much braking power when turning but idk. but ya willwood kits are nice and not to pricey. and you can get as ls rear for like 200bucks
- Wed Mar 31, 2010 2:04 pm
#184802
But wouldn't you have to change the whole rear trailing arm for a drum to disk conversion?
- Wed Mar 31, 2010 2:19 pm
#184804
That is correct.
- Wed Mar 31, 2010 2:38 pm
#184807
Ok, that's wat I figured.
