- Thu Mar 04, 2010 2:49 am
#179053
Offset Calculator
http://www.1010tires.com/WheelOffsetCalculator.asp
Tire Size Calculator
http://miata.net/garage/tirecalc.html
The http://Miata.net link above has a calculator to help you determine what width and sidewall tire you will need to use when buying larger rims to keep the same outside diameter.
Tire Stretch Calculator
http://civic-eg.com/rim_data/stretch_calculator.xls
I found this on a VW site. It's in German, but it doesn't take too long to figure it out. Original specs on left, new specs on right.
Stock Tire Size List
Find out what size OEM tire goes on your civic.
http://www.dragtimes.com/Honda-Civic-Ti ... -n214.html
Tire and Rim/offset size calculator
http://www.rimsntires.com/rt_specs.jsp
