- Wed Jan 18, 2012 3:19 am
#290678
I have some Morimoto D2S mini projectors in my SPEC-D black housing headlights. The light out put is nice, and the cut off is so sharp!!!
However** I helped my friend retrofit some FX-R projectors into his BMW E46 cuz he did not want his stock e46 projectors, and they are amazing! The light output is better than the D2S mini's and the color band is much more defined! Looks very exotic.
With the D2S mini's, you will also not be disappointed, and the swap is a piece of cake! took me about 2.5 hours I believe for both headlights. There is not cutting involved (other than having to trim the shrouds to fit the headlight unit because they are a bit too long) because once you bake the lens off, you can place the projector in and screw is in place from the other side.
The FX-R's should fit without sticking out too close to the glass, but you will have a ton more cutting involved!
Not to mention you will need to do a lot of beam aligning before being absolutely certain that you can JB weld or glue (however way you want to install them) them to the headlight unit. There is more risks involved but better output.
not too sure about the H1's not experience with them, sorry
Here is some pics:
Supper straight cut off in fog, and against a wall, etc...
