- Sun Aug 24, 2008 2:47 pm
#67168
ok.....
1. I removed the front bumper(5 screws on top, 2 bolts on the bottom ,and 1 screw on each side of the corners of the bumper), headlights, and turn signals. 1st pic
2. I mounted the ballasts in the most secure spots I could find near the headlights. 2nd and 3rd pic
3. I then put the HID bulbs in where the regular bulbs go and locked them in with the hinge thats on the headlight housing. There are two sets of wires running from the bulb. One goes the the stock adapter, the other goes to the ballast. After that I turned them on to make sure it worked.
4th and 5th pic.
Its really simple and doesn't take too much time. I'd say 1-1.5 hours tops.
Its DIY because you're doing it yourself rather than paying a performance shop to install it for you.
