- Sun May 20, 2012 6:00 am
#305509
teal_dx wrote:As long as it is properly welded it should be fine. Good welds are a must though, do some research & practicing if you have not welded much before. Be sure to properly seal both areas after welding so it will not rust
hmm well i didnt weld it 100% but its about 80% of the cut is stitch welded and seemed strong. hope it works...although the leak didnt come back with a glass full of water but ill have to wait and see on the next rain storm
92civicEGsedan wrote:weld it then go back over your weld with JB weld
whats that? adhesive?
fatcoupe wrote:if you do some practicing maybe make a diy? havnt found a good SIMPLE "basics of welding" guide thats understandable. so if you find anything out or are already a great welder post it in here. would like to see it
i didnt really take alot of pictures..but i practiced with the scrap i cut off from quarters. as far as the setting goes i just followed the chart on the lincoln. which is i think c-1 on a 120v(if it makes the difference)
as far as the technique go i just followed this video
http://www.youtube.com/watch?v=DEDHR-Nst6E
but honestly. the first few tacks were shit. but youll get used to it real quick and get the idea of how long you can hold each tack. the worst thing to do though is rush. since i only rented a welder for a day(budget issues) i was in such a rush that my driver qp wasnt aligned and had a 1/4 gap all around thhat was a pain to tack. and it took a hell of bondo to get it "smooth".
