Appearance, Paint & Body Work
#62599 I had this issue with my hatch, and am developing it with the Teg too, the hood latch seems to preventing it from shutting properly, was a bitch the other night in the walmart parking lot trying to shut my hood and it wouldn't shut :x
if you push the cable with a screw driver it allows it to shut, anyone know a fix for this? I was thinking just spray the hell out of it with rust check or wd40 :?
By BreCalmor
#63914 My 95 Civic has had this problem for years, but all of a sudden, the stupid VA state inspector failed my car for it...
Anyone have a quick fix for this?
I have tried finding a replacement cable, but none of the online parts places have the exact part.
Anyone replace it and can tell me how hard it is?
Thanks !!
By 94delsoltyper
#169165 spring on the back closest to the radiator needs to be replaced with a stronger one, same spring that pull the little handle back into place
#169169 This happened on my EK until one day it wouldn't release to open. I had to go up under the bumper, what a PITA that was.
I tool it off and lubed the hell out of it and it's been good since.
By dawg316
#169360
teal_dx wrote:This happened on my EK until one day it wouldn't release to open. I had to go up under the bumper, what a PITA that was.
what lube did you use. my eg has a problem with the hood not latching properly and its the same spring. i used wd-40 on it and it worked for a lil bit now its back again
By edcortez9
#169391 yeah its the spring that doesnt work anymore i shut use to shut my hood really hard each time and it works like that but imma just replace the whole latch when i paint it .
By marquisdee1018
#170908
teal_dx wrote:I used PB blaster to break it loose and then moved it a lot to break it in. Then I put some Tri-Flow lubricant on the latch and it's been good since
Yeah I just shot my with pb blaster and it hasn't given me any more problems.
