By Adrian91
#209044 Is it possible to add cruise control? Ive got a cx with a b18c swap. Also, my cluster seems to be off by a lot, rpm, mph, temp gage does not work, but fuel works, can i fix this by putting in a new cluster and re-connecting everything?
By Classiccarsrule85
#209047 first question yepp you can put in cruise control.....
the list
http://civic-eg.com/viewtopic.php?t=1474
http://causeforalarm.thecarthing.com/ve ... index.html
and the specific one....
http://causeforalarm.thecarthing.com/cr ... index.html
Cluster question
that might help but it may be something to do with the speed sensor or engine temp sensor....
but if you can get your hands on a cluster then swap it quick and see if its the cluster then your good if not then there may be another issue
