#36499 I've been thinking about raising mine up a lil bit. My valvecover rubs the underside of the hood, and I've already made all the adjustments you can, but it still rubs.
#36513 I kinda want to do it too..but just a lil...not all that much.
By 93greenEG
#36539
LowTEC-Derbo wrote:
Graham wrote:Slightly = 8)
Loads = [smilie=nono.gif]
i got 1/2 inch. :]
how does it look with just 1/2 inch
By LowTEC-Derbo
#36546 only pic i got of it right now in daily mode. I actually dont like the look at all. Testing to see if it helps with my catchcan venting. I noticed my oil temperature is lower on the gauge now, but that is probably because the engine is vented more as the sensor is by the oil filter.
By bietelboer
#36562
XocruncheyriceoX wrote:People with H22 swaps need to do it because of clearance issues.
Thats not true, i know a few H22 EG's and they all have no prob with there hoods...Just use the right parts :wink:
Personally i dont like hood raise, but if it has a funtion then it has to be :P
By split sec eg
#36571 i wondering when it rain does water get into the engine?
split sec eg wrote:i wondering when it rain does water get into the engine?
Yes, the rubber stripping that seals the hood is no longer doing what its supposed to. I doubt it would hit the engine though, it would probably just run down the firewall.
#36593 FLUSH FTW!!!! :lol:
By LowTEC-Derbo
#36648
the water will run to the fender corners just like how it would be if it is flushed. the slit is only minor, like if you opened a window a little on a rainy day. the water is insignificant, as its been raining and my car's engine is still decently dry.
By Hereg6
#36649 My hood is raised just a little bit
Rain water doesn't get under my hood
By Split_second
#36818
split sec eg wrote:
Split_second wrote:i do it cuz it looks good givers it a unique look. plus ima need it wen my super charger goes in
ummmm okay when? tony?
2late i dedicde ima let putt take it since he want it i aint shady and u kno dat
By split sec eg
#36920 yea i know ... hes the slow in the team . he needs it
By boxcarracer0260
#37013
Hereg6 wrote:My hood is raised just a little bit
I don't have that problem either. Plus the reason I raised my was for better cooling of the engine bay when you race ( it help the air pass smoothly without having to recirculate) as well as a little added down force.
