By pong
#121543 hay everybody...can someone help mi whit my B18c swap into the 92-95 hb...!! i have a b16 a2 wiring in my car.. i like to bolt on an b18c motor include his ecu
#121814 should go in just like the B16a. You have the dohc vtec harness already in the car which makes it that much easier.
By courtottman
#121848 should be a straight swap, i'm doing one atm, yours is efi and you have ecu, maybe a downgrade harness will be required depending on the age of the b18, im sure some of the more experienced blokes on the server will know if you give them more details
By pong
#121868
Greasedmonkey wrote:should go in just like the B16a. You have the dohc vtec harness already in the car which makes it that much easier.
Y es but everybody here in Netherlands have a b16a turbo..I like somethinge other...i got all the b18c gsr..... and later come the turbo.!!
i think he means that all you have to do is put the b18c in the car and the b16a2 wires should plug into the b18c
