By matt is (eg6)
#132295 i have the screws out of the top and the screw out by the hazard switch is there anything else im missing or does it just pull right out??? im just asking before i break it lol
By eg_turbo_hatch
#132305 those are all the screws now you just have to pry/pull it out just watch the vents thats where they tend to break if your not carefull
By matt is (eg6)
#132310 thats my problem is there a technique to get it out by the vents??? because thats where im having trouble
By eg_turbo_hatch
#132313 no real technique just work your way around the edges slowly pulling more out i always start by the hazard switch
By matt is (eg6)
#132316 thats what i was trying lol but i guess i will try agian thanks guys 8)
By OmarG
#132340 I was really freaked out the first time too. I was afraid I would break it. But after about four times of removing it, I'm a pro. I can take it off in about two minutes. Blame it on my JDM clock and JDM si-r cluster. :P
Pro tip, grab a flat head screwdriver, or a plastic putty knife to wedge it in there where ever you feel the clips giving you resistance. I usually have a hard time getting it off at the vent nearest the tach on the cluster. or the one furthest to the right. Once you have all the clips, just wiggle it back and forth until it jostels loose.
Hope this helps! :thumb:
By matt is (eg6)
#132601 yeah i got it off lol i was just scaredi was going to break it... i was just putting in an ex cluster becuase my stock cx one doesnt have a tach...thanks for the help guys :thumb:
