By kAce
#167334 My car does not have the sticker on the side of the door stating the right psi specs.
rims 15/7.5
tires 205/50
was wondering how much psi should i run.
By kAce
#167712 probably gonna run 34 in the front and 32 in the back
By Sentry
#167800 The sidewall is the max recommended pressure for that tire. Use Honda's specs.
By elrompetoto
#167844 i run 51 psi thats the max my tires take
By Apexracing
#168114
elrompetoto wrote:i run 51 psi thats the max my tires take
ekk thats way too high, you must be wearing the centers of your tires right out.
By elrompetoto
#168118 Na I have 0 offset rims and a lot of camber and I need the tire as hard as posible cuz I take turns hard I can't aford 2 have the tire play on the rims go in and out and shit
By Apexracing
#168121
elrompetoto wrote:Na I have 0 offset rims and a lot of camber and I need the tire as hard as posible cuz I take turns hard I can't aford 2 have the tire play on the rims go in and out and shit
then you should of stated that before an idiot goes and does the same with a stock setup.
By elrompetoto
#168188 I never told no one 2 put 51 psi I told them if they want they can put the max that it says on the wall it all depends on how good or cheap ur tires r
By Apexracing
#168362 good or cheap tires if your running stock camber you will wear your inner tire out fast if you over inflate.
