- Thu Jul 07, 2011 12:09 am
#262577
this has probably been asked tons of time. but i just cant find the answer. can i use the rear sway bar from a 92 integra on my hatch. mine didnt come with one and im on a budget like some of us at the moment. i know the 94 does but what about the 92? i have a donor car but i prefer if some on lets me know before i buy.
- Thu Jul 07, 2011 1:10 am
#262582
yes, but use your EG mounts.
- Thu Jul 07, 2011 1:14 am
#262585
yes it will with eg,dc mounts
RWMIII wrote:just found this: http://civic-eg.com/viewtopic.php?t=16754
- Thu Jul 07, 2011 1:26 am
#262589
so i CAN use the DA integra sway bar with the eg or dc mounts? just double checkn.
- Thu Jul 07, 2011 1:37 am
#262597
Yessirr!!
if you click that link, that is my eg 4dr with a da/ef rear sway bar
here is the pic
if you have any questions let me know
i think im the only one here or that i know of with a da rear bar on a eg
and the whole rear disc of a da teggy will fit your car if ur ever looking for a rear disc brake conv.
civic eg-k wrote:so i CAN use the DA integra sway bar with the eg or dc mounts? just double checkn.
Yessirr!!
here is the pic
- Thu Jul 07, 2011 1:39 am
#262598
I have a DA to go rape....
94_jdm_ferio wrote:and the whole rear disc of a da teggy will fit your car if ur ever looking for a rear disc brake conv.
- Thu Jul 07, 2011 1:41 am
#262599
yessir! the whole everything will fit
the lca's
the sway bar with the eg/dc mounts
the upper arm that replaces the camber kit
the trailing arm
just make sure u get the e-brake cables
and the 40/40 prop valve
RWMIII wrote:94_jdm_ferio wrote:and the whole rear disc of a da teggy will fit your car if ur ever looking for a rear disc brake conv.
the lca's
the trailing arm
- Thu Jul 07, 2011 1:43 am
#262600
94_jdm_ferio wrote:RWMIII wrote:94_jdm_ferio wrote:and the whole rear disc of a da teggy will fit your car if ur ever looking for a rear disc brake conv.
the lca's
the trailing arm
- Thu Jul 07, 2011 1:51 am
#262601
thnx i knew there was a diffrent route to take im not much of a risk taker.
for now ill just swap out the sway bar and work my way up. unless i want to add shiny parts.
whats the size on that?
you know how they say cut once measure twice. lol
- Thu Jul 07, 2011 3:18 am
#262612
the sway bar is a 13mm, and yeah there are alot more DA teggys out there that have rear disc, and its a direct swap
civic eg-k wrote:thnx i knew there was a diffrent route to take im not much of a risk taker.
- Thu Jul 07, 2011 7:51 pm
#262727
thnx guys you guys are really helpful. havent been on a forum that can at least lend a hand of info.
