- Mon Feb 27, 2017 5:13 am
#361301
Bought a brand new tps sensor to see if it would help with my acceleration issues. I have tried to calibrate it took me awhile to get it to read, but at closed throttle I was getting around 2.4v and at wot it was at 4.9v, I'm very confused cause even when moving the tps sensor to lower the volts down at CT/OT it barely changed. As of now it drives okay but I want to get it right, would this have to do with the way I tensioned the cable/throttle stop screw etc...?? Thanks in advance
If you have everything installed correctly and you can't get the TPS to see 0.49 volts at idle remove the throttle cable and double check. If that doesn't help and you have previously moved the set screw (the one under the throttle wheel) you may have to re-adjust that as well. You don't want the throttle cable as tight as it goes. It should have 10mm of deflection in the cable to prevent issues.
Instagram:
https://instagram.com/enjoymotorsports
Website:
https://enjoymotorsports.com
Instagram:
Website:
