By 93hatcheg
#91077 can loose axle nuts cause i vibrations in the front end when i punch the gas at lower speeds or when cruising at freeway speeds? can you bend axles? that would cause this too huh?
anyways im sure you figured out that that is a problem with my eg lol, anyother suggestions would help too. OHH hey could changing my front LCA's to ones that hold a sway bar have changed my allignment? thanks for the help :wink:
By hatchin06
#91111 As for your first question, I would say that its an axle or a mount that needs to be replaced. For your second question Idk lol these guys will take care of you.
By boosted94
#92824 I'm gonna go ahead and say that the lca swap should not affect alignment to horribly, the si's are built on the same platform with the same dimensions. however, i would suggest getting an alignment done, not to expemsive and will lenthen the life of your tires and other steering components by relieving awkward stresses.
By 93hatcheg
#94508 ok cool thanks guys ill get that done asap
By doitpropa
#96211 does it stop and start again at certain speeds or just all the time
