By RaMsTeIn_
#114951 while my car was at the paint shop, fixing some electrical problem caused when they put the rear part of the car together, a fuse melted so i was without lights in the tail and in the interior, while in the shop, my HID where stolen so i had to drive my car in the dark back home only with the fogs i installed in this week, so i did not had the chance of testing them in the night and i noticed they are like a luxury only, cuz i cant see nothing with them in the dark!
Is there a way to adjust the light beam to go higher?
PD: The paint shop is going to pay for my HID, i wanted to put 3,000k instead of the 8,000k i had, so now i don't need to buy a new pair of bulbs :hehe: :roll:
By spiritR
#114959 you can take out the little reflectors that are in front of the bulb it'll be alot brighter
By RaMsTeIn_
#115398 is there a tutorial or something to know a bit what i am doing?
By KuEy
#117060 post pic of the foglight up. is it the oem fog kit or aftermarket kit you installed?
#117135 if its a OEM or OEM style, then yes, you can adjust them. there are adjustment screws on the back of the housing. much like the head light adjustments.
Greasedmonkey wrote:if its a OEM or OEM style, then yes, you can adjust them. there are adjustment screws on the back of the housing. much like the head light adjustments.
wait if you have to adjust them from the rear, how will you know if they are level and aimed properly, cause you'd have to take the bumper off wouldn't ya? or are they accessable from the front by removing the cover?
By Joplies
#117163 The fogs i have for my EG8 you take the face plate off and you can see the adjusting screw right in front of you. Hope that helps. (they arnt OEM but they are the replicas)
i believe you take the cover off of them.
By RaMsTeIn_
#118152 thanx, i will try that, mine are oem style
By marvinp8700
#118153
correct
By RaMsTeIn_
#119746 got my car back just about an hour ago, and removed the cover, and didn't see any screw, is it possible to post a picture of where it is?
