- Fri Nov 13, 2009 3:29 am
#156316
EMAIL ME mikefritz86@yahoo.com
$3000 OBO
93 Civic DX Coupe
red w/ black interior
5spd
WORKING A/C (winter time but for next summer you'll be cool)
D16Z6 swap
MINT tranny (no grinds or noises)
ACL race bearings
ZR 4-2-1 header
Almond Valve cover
NGK wires & plugs
EXEDY stage 1 clutch (around 1k on it)
OEM Si/EX intake
OEM Alt belt
OEM A/C belt
OEM oil pan gasket
OEM rear main
OEM axle seals
OEM Dist. o-ring
fuel filter
OEM Tstat
OEM rad hoses
OEM exhaust w/ GSR muffler
OEM Timing belt
OEM water pump
OEM VC gasket w/ tube seals
+++and more to list but you get the point
Suspension
13inch steelies rears are GY integrities fronts are Snow tires(winter mode)
D2 lowering springs(still not fully settled)
KYB GR2 shocks
new shock bolts
ES poly bushings
GSR steering rack (freshly aligned by redEK)
new outer tie rod ends
EX front lower arms
EX front sway bar
new front ball joints
Skunk2 front camber kit
new pads
new rotors
new calipers
++++ more
Interior
Black
Gray Integra seats
MINT OEM floor mats
type R shift boot
20% tint
Pioneer CD player
all new dash lights
recovered door panels in some hippie looking quilt stuff(tan)
OEM clock
EX gauge cluster
CARPET HAS A WEAR SPOT UNDER THE DRIVERS MAT
Exterior
OEM milano red
painted mirrors
painted side moldings
painted rear plate valance
EK side skirts
JDM headlights(PWJDM yellow bulbs)
Vision Smoked amber corners
EX lip
Antenna block off
front fogs(yellow housing)(needs harness and switch)
decent for the year(bubbles of rust on pass. side quarter)
hood fitment is a little off (may have been in a slight fender bender im assuming)
car shines when its clean
3500 OBO hell lowball me
PICS are from night bc i work 830-8 so no time
$3000 OBO
93 Civic DX Coupe
5spd
D16Z6 swap
ACL race bearings
ZR 4-2-1 header
Almond Valve cover
NGK wires & plugs
OEM Si/EX intake
OEM Alt belt
OEM A/C belt
OEM oil pan gasket
OEM rear main
OEM axle seals
OEM Dist. o-ring
fuel filter
OEM Tstat
OEM rad hoses
OEM Timing belt
OEM water pump
Suspension
KYB GR2 shocks
new shock bolts
ES poly bushings
EX front lower arms
EX front sway bar
new pads
new rotors
new calipers
++++ more
Interior
Black
Gray Integra seats
MINT OEM floor mats
type R shift boot
20% tint
Pioneer CD player
all new dash lights
OEM clock
EX gauge cluster
Exterior
OEM milano red
painted mirrors
EK side skirts
EX lip
Antenna block off
