By Classiccarsrule85
#150673 so im not sure that there is a category on here for exhaust so im placing it on here instead. so im wondering what the difference between the hatch and coupe/4dr exhaust is.....since im getting rid of my magnafart cannon in favor of a cheap stock exhaust i bought at the yard thats brand new so yea just wondering im thinking tho the coupe and 4dr are longer in the axel back department?? ut am not sure and i cant really take my exhaust off fast and putit back on quic to run to the parts store if need be....so thats why im asking.
Thanks for any assistance
By Apexracing
#150684 if yours has a cx exhaust up front then that means your cat is built into or right up on your header. and not where it would be down on the pipe on a sedan or coupe exaust, so you might want to grab another header too. ive thought about taking my sedan exaust as i just replaced it before i determined the block was bad so its all shiney new, i had just thought of mounting it all up on there and cutting the areas that didnt fit quite right then sleveing them and clamping it.
#150693 Yep, you will need the entire header/cat/mid pipe from a dx/si hatch. The coupe & sedan exhaust is too long, but you can grab the header/cat from those, as they are all the same.
You can use the axle back rear section from any hatch though.
So here's what to get:
Mid pipe = dx/si hatch (cx mid pipe is longer I am pretty sure)
axle back = hatch are all the same size
cat = dx/si hatch, sedan, coupe. (del sol too I think)
header = dx/si hatch, sedan, coupe. (del sol too I think)
By Apexracing
#150713 good to know ill keep my new cat for sure then and just sell the new sedan mid pipe and axle back and new muffler on here :thumb:
#150806 well i already got rid of the cx exhaust while i was doing up the car a bit last summer. it now has a dx header, si midpipe, teg custom cat (straightpipe with cat outsides) and now thanks ot a good days worth of work a semi custom oem muffler from a 4dr that i cut down and elded up to fin the hatch and i also cut the end peice off of it. and rewelded it at a different angle since well i was bored and wanted something different....
now lets just say its quiet as heck half the time im wondering if its still running.
and thanks for the help as well thats good to know stuff in case i need something else done soon with my b swap im planning
