- Sun Jan 05, 2014 11:23 pm
#341008
while driving my speedometer goes to zero and check engine light comes on,later it starts working by it self. any ideas why this may happen?
- Sun Jan 05, 2014 11:51 pm
#341010
Do you know witch fault code the ecu gives?
- Mon Jan 06, 2014 12:06 am
#341011
its probably the VSS
- Mon Jan 06, 2014 4:48 am
#341019
Yeah, your car is OBD I. Check your codes by following this tutorial. VSS is Vehicle Speed Sensor, which would throw a code 17 when it's out which causes your speedometer to just stop working basically.
jedrick wrote:no i dont know any codes,went to discount auto parts and they said ,they arent doing any older cars only 1996 and up mine is a 95,what is the VSS?
- Mon Jan 06, 2014 2:48 pm
#341025
Definitely sounds like a VSS. Not too expensive and easy to fix
