- Tue Apr 15, 2014 1:38 pm
#344589
Don't have the car running
Hook up the gauges and the vacuum pump to the gauges
Open high and low side valves
Vacuum for thirty minutes
The needle should read -29hg
Closed both valves before turning off pump
Let sit for 30 minutes
The reading needs to stay at -29hg...if not, you got a leak in the system. You would need to find it and fix it.
But if it does stay I suggest you fill the system with freon. Around 22oz should be good or look at the drier sight gauge and make sure it has no bubbles and clear. This would take around 20-30 while the car is running.
I gotta write a whole other paragraph on servicing for you though. I'm at work so I don't have the time
94' civic si
JDM B16A w/AC
My daily driver:
http://tiny.cc/3bdut
K3 GSXR 1000:
http://tinyurl.com/3u6obdx
