Disc brake swap conformation
Fri Jan 01, 2010 5:44 pm
by FairViewLife
So I have a 1995 civic 2dr dx coupe. I recently purchased a 1994 acura integra that is wrecked. I want to do the rear disc brake swap and I just wanted to see if the bb and mc would work on my car without having to bend and re-flair the brake lines. I do know that this car has abs and from what I have searched and read this might make a difference. Also I think I might need the "4040" proportion valve from a 95 civic si witch I have found on ebay but I wanna make sure its the right one I need first. Any help is much appreciated thanks.
Re: Disc brake swap conformation
Fri Jan 01, 2010 5:52 pm
by Classiccarsrule85
FairViewLife wrote:So I have a 1995 civic 2dr dx coupe. I recently purchased a 1994 acura integra that is wreaked. I want to do the rear disc brake swap and I just wanted to see if the bb and mc would work on my car without having to bend and re-flair the brake lines. I do know that this car has abs and from what I have searched and read this might make a difference. Also I think I might need the "4040" proportion valve from a 95 civic si witch I have found on ebay but I wanna make sure its the right one I need first. Any help is much appreciated thanks.
well since your coupes a dx it most likely dose not have abs thusly you wont be able to use the integras bb/mc or prop valve what you need is a master cyl. off a 88-91 civic ex/si or possibly a 91-93 integra may work i know youll want the prop valve off a civic or integra without abs so pretty much you wont be able to use a 40/40 style from a civic si.....since that car had abs. more than likely you will want to see about a integra rs since thats the only car i know of 94+ that did not come with abs....
so quick summury.....
stuff from the integra you have no nothing but the rear and front disc will work from that brakeing system....
What you want is stuff from a 88-91 civic ex/si (master cyl) since they did not come with abs....or you will want possibly a master cyl from a 91-93 integra im unsure tho if that style integra will work but i know youll want a prop valve from a non abs civic/del sol or integra with rear disc...
hope that helps
Fri Jan 01, 2010 5:58 pm
by FairViewLife
hope that helps[/quote]
ok thats what I was thinking. one quick question. since the bb and mc won't work for me I still want to do the brake swap and still just use my mc and bb thats in the car now. do I need a 4040 from a 95 civic si or the one from a 90-93 teg non abs?
Fri Jan 01, 2010 6:12 pm
90-93 integra it wont be a straight 40/40 thats for abs cars what you need is a non abs prop valvefrom either a si or ex w/o abs possibly a 92 civic si? or like i said integra rs or 90-93 integra prop valve....
the [prop valve you get should look like yours but have different numbers on it....
Fri Jan 01, 2010 6:45 pm
by FairViewLife
Fri Jan 01, 2010 7:03 pm
by berg89
Grab one out of a junk yard. A lot cheaper.
Fri Jan 01, 2010 7:10 pm
by FairViewLife
the only junk yard around here has one 4 door 92 civic and it has been stripped. So this is my only option I just want to make sure it is what I need
Fri Jan 01, 2010 9:03 pm
could ask in the wanted area for one i can go ahead and look for one soon for you....from my junkyard i may actually have one in my shed just gotta look once this snow is shoveled up a bit if your not in too big of a rush to get it done i can go help you get parts...
Fri Jan 01, 2010 10:16 pm
by FairViewLife
yeah that sounds great if you have one. i dont mind spending the $30 for the one on ebay.. but im not in a hurry. I have to wait till some of the snow melts around here to move the teg to my house anyway
Sat Jan 02, 2010 1:45 am
well as luck would have it was unabel to get into my shed the lock froze so tomarrow hoepfully i can get it undone but never fear i got a parts stash in my basement as well lol......
I found a 58/41 i think it is or its reversed 41/58 prop valve that you can use i can do probaly 10 or something like that +shipping throw me an offer and in the mean time ill see what other prop valves i have....since i should have a few for a rear disc swap just they all seem to have different ratios
Sat Jan 02, 2010 2:50 am
by FairViewLife
ok sounds great. whenever you find the right one just let me know I have paypal. just from what i have read on honda tech the one I need is stamped 4040. I also read that that doesnt mean the ratio, its just stamped with the 4040
Sat Jan 02, 2010 3:00 am
FairViewLife wrote:ok sounds great. whenever you find the right one just let me know I have paypal. just from what i have read on honda tech the one I need is stamped 4040. I also read that that doesnt mean the ratio, its just stamped with the 4040
I do beleive teh 40/40 is the I shaped one not the one with the 2 inputs and 4 outputs....
that one that i said i had will work see if you cant read teh numbers on your dx that way you can see which would best work for your car. also if your area has snow id suggest buying a spray can of lube and penatrating oil for the metal line that will need to be undone.....
but yea im almost certain the 40/40 is I shaped
Sat Jan 02, 2010 5:54 am
by FairViewLife
yeah i double cheaked it and it is the one with the 2 going in and 4 going out
Sat Jan 02, 2010 4:50 pm
yea i did the same ill look for you up at the junkyard quick probaly monday dependingon the weather i cant drive my car in the snow without losing control over the stupid thing....but yea ill see what i can do for you....also ill check my shed first just in case.
