- Tue May 21, 2013 3:10 pm
#331989
So, my engine runs great, except it pushes coolant through the resivoiur... Not smoke, no oil in coolant or the other way around.. So I've ruled out head gasket, I am however using the stock civic single core radiator, any advise???
- Tue May 21, 2013 3:13 pm
#331990
Like perhaps I need a dual core?
- Tue May 21, 2013 6:28 pm
#331996
Well you're pressurizing your cooling system enough to bypass the radiator cap and spew out coolant so something has to be doing it. I'd pull the plugs and use a rubber tip on an air gun and pressurize the cylinders with the cap off the radiator and see if I can see bubbles or anything weird.
1992 Honda Civic SIR-S
