- Sat Jul 14, 2012 12:56 am
#310866
I bought a eg8 the ppl i bought it from put 7quarts of oil in it like the smart ppl they are i did a oil change and tune up nd it still wnt start i pulld out the injectors nd cleaned them it get spark nd gas i jus cant figure it out can anyone help me out????
- Sat Jul 14, 2012 2:18 am
#310870
Check ur fuse an relay an the ur timing
- Sat Jul 14, 2012 6:35 am
#310880
try taking one spark plug out and ground it and see if you get a spark.
in other words: take spark plug 1 out, put it into the spark boot and put the other end on a metal ground. ask some one to crank the engine and see if you see a spark.
sounds like you might have an ignition problem
- Sat Jul 14, 2012 10:29 pm
#310940
timing could be off too as mentioned
My EG Hatch Build
http://civic-eg.com/viewtopic.php?t=22106
1993 Civic SI Hatch - project!
1999 Acura EL - winter beater!
- Sun Jul 15, 2012 10:40 am
#310969
My account> profile> scroll to bottom of page ... Hope this helps!
Follow my Build thread!! - http://civic-eg.com/viewtopic.php?t=23404
- Sun Jul 15, 2012 12:59 pm
#310973
are you asking what timing is or are you saying its right?
I had an old toyota truck that wouldnt start after a headgasket change. it had spark and fuel, turned out the timing was off the whole time
you could also do a compression test i suppose to make sure you're getting compression in all cylinders but i dont know if that would be ur problem
Haze.703 wrote:Its gettn spark And the timing?
My EG Hatch Build
- Mon Jul 16, 2012 11:48 pm
#311133
Ok well if the engine was running before and the belt wasnt touched or anything then shouldn't be timing
My EG Hatch Build
- Tue Jul 17, 2012 1:14 am
#311140
So it ran before and the only thing you did was change the oil and take out injectors and put them back in?
what happens when you try to start it now? doesn't turn over? just cranks? sputters?
