By KRYSTED9354
#50256 i have had this problem for a wile now its getting worse, my exhaust sytem SOMEWERE is making a metal banging noice ? only on low rpm 0.500-2.000 IT IS A FYLL aftermarktet, exhaust !! payeed like 250$ for it not the best but can it be the resonator inside broke and rattles ?? thanks.
#50258 could be a heat shield.
while it is idling, go under and hold them still with a stick or broom handle. if it gets quiet when you are touching one of them, then that's the one that is rattling & rip it off or bend it back so it is quiet. :thumb:
By stefan
#50275 That could be it, yeah.
But cheap aftermarket catbacks fit like shit actually.
There is a chance one of the brackets on the midpipe is banging to your bottom end.
Or if you have a short shifter, that could be rattling to your midpipe, especially when you're running a B-series.
By EBT WeSt
#50323 I know my exhaust rattles because it its my Type R Rear lip
By KRYSTED9354
#50330 no stock shifter and no heatshields it sounds like something inside, ill check it around.
#50379 could be the muffler bearings. :?
york62 wrote:could be the muffler bearings. :?
do you mean the baffles in the muffler?
By Xaser
#50390 I have this problem, only really happens about 1200, for me and its really annoying. I thought it was gonna be the heat plate but it has turned out to be my cat, the catalyst or what ever in side has come loose and is rattling around in side it.
