- Fri Dec 17, 2010 9:58 am
#228479
Once again Teal thanks, looks like I'll be stealing more tips from you lol.
- Tue Dec 21, 2010 12:50 am
#228959
Ok, Here's a twist to this mod I need help with. How could I tap into the fuel line if I plan on running a Wet Nitrous kit? I think most of the single fogger kits come with a "T" that goes in the rubber line. With this braided line, you are cutting out the part the rubber line that would have been tapped into. Any suggestions or ideas? Teal?
- Tue Dec 21, 2010 4:18 am
#228979
Do they make "T"s than can use -AN fittings? That would probably be stronger and look as good as the rest of the fuel setup.
- Wed Dec 22, 2010 1:17 am
#229141
(LOL @ myself)
Yes, they make a fitting that will thread in and look as good. About 5 minutes after I posted that question, the light bulb in my brain clicked on.
DISCLAMER - I work weird hours and had just got out of bed when I posted the question, and hadn't had any coffee at that point. LOL!
Thanks Teal.
teal_dx wrote:Do they make "T"s than can use -AN fittings? That would probably be stronger and look as good as the rest of the fuel setup.
(LOL @ myself)
Thanks Teal.
- Tue Feb 08, 2011 2:43 am
#237516
has anybody done this on a b-series if so did you use the stock rail and what size was it ???
EJ2 FoReVeR. My car is a whore
build thread http://civic-eg.com/viewtopic.php?t=18655
#1 COUPE CREW MEMBER
- Sun Mar 27, 2011 10:08 am
#246495
nice fittings!!!
- Sat Apr 09, 2011 12:51 am
#249221
a new twist to this mod just move the stock filter to the back of the car by the tank so theres no filter under the hood trying this on my friends crx when we do his ls swap
- Wed Jun 22, 2011 7:43 am
#260352
Just for looks
rmp705 wrote:noob question is this for better mpg or jus for looks
Just for looks
- Fri Jun 24, 2011 7:45 am
#260745
It should be exactly the same for a B16
Erik_EJ1 wrote:is this the same for B series? b16 to be exact
- Sat Jul 23, 2011 12:56 pm
#264647
Not sure about the H rail, but I know the b & d are the same size. I bought all my stuff for a b motor, but unded up using it on my d. So using that crazy logic (LOL!) i would think the H was the same size
kross wrote:is the h22 rail the same size? i would check myself but seeing as im 300 miles away from it at the moment... haha
- Wed Dec 14, 2011 9:50 am
#285383
I found out that Earl's have a new hardline adapter, that doesn't require to re-flare the hardline:
http://www.jegs.com/i/Earls/361/165006/10002/-1
Looks to be easier than using a tube nut, tube sleeve and AN-adapter. Plus you don't require the flare-tool. Just don't know if the max 50psi pressure will be an issue.
- Thu Dec 05, 2013 2:33 am
#339667
Bump for lost posts!
Team XXX Racing/WGHonda
- Page 3 of 3
- 1
- 2
- 3
