- Thu Nov 04, 2010 12:39 pm
#221556
good luck with it buddy, hopefully someone will give you a definitive answer on the head studs. As I say, im sure you should use new ones but not sure if you'd get away with using the old ones.... dont want another gasket going from corner cutting eh
- Fri Nov 05, 2010 12:52 am
#221646
92-95 head bolts are stretch bolts and are not designed to be re-used although some people do.
Tonyp436 wrote:Hey I'm about to do this and I have just about everything....just one question... do I need new headstuds?... I heard that I need new headstuds....
- Sun Jun 26, 2011 1:43 pm
#261053
Sorry to drag up an old thread, but i just had to re-RE-do my headgasket
First time out, I *did* re-use the old head studs because I knew no better, and lo and behold, a year later I had to re-do the gasket.
So thats one person voting for " don't re-use ".....
This time out I bought ARP studs and went that route. I apparently need to re-torque them though?
I've run it probably 6 or 7 times since the gasket re-do.
Totally off topic, but the gasket between the header and downpipe is todays chore....
The Slow and the Curious- Noob to the tuner scene...
- Fri Nov 11, 2011 3:10 am
#281057
how should i break in the new head gasket just drive normal or baby it?
- Fri Nov 11, 2011 5:09 am
#281066
normal driving is fine. don't forget to re-torque if you used head studs.
- Wed Jul 04, 2012 6:27 am
#310102
cant believe how easy you have made things for me prob a late question but would i be able swap my TB while i had all this off or would it be easier do them seperate
vroom vroom as fast as you cant catch me im in a vtec man !!!!!
95dx hatchy=http://civic-eg.com/viewtopic.php?t=24581
- Thu Dec 20, 2012 4:22 am
#322534
Sorry to bring up an old thread, but I was just wondering what else should I replace when I do my headgasket? I know the timing belt, water pump, and belt tensioner, but what else? I have a mini me z6
Tuner cars aren't a waste of money, there an investment
- Thu Dec 20, 2012 1:51 pm
#322548
I wouldn't bother with the oil pump unless rebuilding the bottom end. I would replace the head studs as they are stretch bolts on these motors - or replace them with ARP head studs.
- Thu Dec 20, 2012 2:58 pm
#322552
Awesome write up. Clean engine bay as well
1992 Honda Civic SIR-S
