- Fri Nov 06, 2009 8:49 pm
#155206
well it is easy. all you need is a basic tool set. 6mm,8mm.10mm,12mm,14mm,17mm and a axel socket. braker bar, jack, and thats about it.. like i said it was also my first swap when i did mine.. jack up the front, remove front wheels and remove axel nut, and lower ball joint. then slip the axels out. next diss connect all wires from motor, and radiator hose, power steering line and fuel line, be sure not to lose the 2 copper washers from the fuel line, also just pull the radiator out to guve more room. next you need to unbolt the header from the exaust then disconect the shift linkage. once you have done this you will have 2 staibleizer mounts in the front, the mount on the pass side, driver side and on the fire wall. and blam it will be out.. you can take the motor out from the bottom if you dont have a engine hoist, just have to get the front up as high as possible. just use a jack to help lower the motor down and slid it out. then repeat backward to install.
if you and atleast 1 more person do this you will have it swaped in a few hours. trust me its cake. i hardly even got my hands dirty doing mine. but i swaped in a b seris motor, not just the same motor. and it was my first honda swap. i didnt have a manuel. but the haynes repair manuel is the best one
so when you start the swap and run into any problems you can come on here and ther will be someone to help
