- Sun Aug 26, 2007 6:43 pm
#21188
Lately, I've noticed that my engine is noisy from around 2400 to 3200 rpm. It is not a low pitch knocking sound, but similar. I thought maybe it could be pre-detonation but I retarded the timing and it is still the same.
The motor is a D16z6 with Eagle forged Rods and forged SRP 75.5mm pistons. The block was bored .020 and recieved all new bearings & micropolished crank. The motor has 1600 miles on it.
Now I've read that forged pistons are noisier than cast... but this noise has only been happeneng for the last 400 or so miles.
The valves were just adjusted around 1000 miles, everything on this motor is brand new or OEM except for the parts above, and ARP head stud kit and XTD stage 3 clutch and 8lb flywheel, and MSD Blaster 2 external coil & cap.
I have zero sound deadening on the car, so I can hear a lot more engine noise than usual through the firewall, so I'm not trying to be too paranoid.... Maybe I just have a loud motor - it runs absolutely perfect.
The sound has me a little concerned though because I'm ready to put the turbo on it and I'd hate for something bad to happen after all the time/$$ that went into this setup.
Also oil pressure is about 50 psi while cruising around town in 5th gear, ~ 25 psi at idle in neutral, and ~ 75 psi while accelerating. I broke it in giving it a little more RPM over time. the car does not smoke at all and the engine runs so strong that I have not even been in as big of a hurry as I should be to get the turbo on.
(slowly but surely)
