- Wed Feb 22, 2012 2:37 am
#295818
ok so i installed a fuel regulator in my 99 honda civic and i think i have bad plugs but for some reason i cant get the car to start i had it started ounce and it was ideling really well and things of that nature but when i turned the car off i couldnt get it to start again what might i need to look for as to why it wount start
I'd start by undoing what you just did and see if it starts then. But first check the obvious : spark, fuel pressure, timing, compression. With those 4 things, an engine will start.
Also moving this to ENGINE - GENERAL since it's not about the Hatchback chassis. Please try to post in the corrct section. There's a guide to posting in the correct section in the Newbie & FAQ secion.
