By Entteri
#64646 Hello everyone and thank you for a great forum! I'm new to this forum from finland. I have a little problem with my D15B7 engine, it uses very much oil, I can't pinpoint any certain places where it might leak. Exhaust gases look like normal so it shouldn't burn the oil at least ? Does anyone have any ideas ?
#64668 IF it uses it and its not leaking anywhere its burning it. valve seals?
By Entteri
#64775 Sounds reasonable. Tomorrow I can start opening the engine, so I will found out tomorrow. Would it be wiser to just take the whole engine out and six it or replace it if the problem is bigger than that ?
By d-mon
#64810 compression test!
By Entteri
#64833 Nice, that is good idea. I check the compression before I explode the whole machine :D
#64838 might as well do a leak down test too, to see where its going.
By Entteri
#64859 So basically just so much testing as possible before rushing to conclusions? It surely is much smarter and possibly time and moneysaving. Any other testing I might be able to do ?
