- Thu Jan 29, 2009 7:48 pm
#93047
Gay, this crap is costing me more and more money when I didn't intend it too. O well how would I go about replacing this? Take the valve cover off grab some vice grips and start turning?
- Thu Jan 29, 2009 7:52 pm
#93048
yea try that first.. it doesnt take much to snap those i also did it.. im woundering where ima find a new stud and bolt. can i use d series studs anyone know?
- Thu Jan 29, 2009 9:30 pm
#93067
dealership or http://hondaautomotiveparts.com
Those bolts are only 8 ft/lb or 10 ft/lb which isn't much at all.
If you can grab it with vise grips then that's the way to go. If it's broken down inside, then try a reverse drill bit or easy outs.
(I broke one too once, it's part of owning a Honda
- Thu Jan 29, 2009 10:37 pm
#93102
http://www.hondaautomotiveparts.com/
- Mon Feb 02, 2009 6:25 pm
#93807
we have no idea what ring around your spark plug you are talking about
what is the ring?
edit:
http://www.hondaautomotiveparts.com/aut ... HEAD+COVER
what no. in the illustration?
what is the ring?
edit:
- Tue Feb 03, 2009 4:19 pm
#93962
Had a similar problem with a D. I simply swore a little and shoved the boot in and out a few times untill luck grabbed it.... You may also be able to grab it with a thin pair of needle nose pliers?
Fuck rehab, boost is NOT an addiction, its a lifestyle.
Nah, who am i kidding I'm addicted.
