By jayEGR
#213269 ok i just droped in my ls b18a1 so i was wondering ,does it matter if i can put in the b18b1 or are all cv axles from the b series are all the same? i was told a certain type come out of the tranny and are to short but dnt remember which cv axles are for my swap :? just need to know if the b1 and a1 are the same or is it different on my coupe :eh: any feed bak fellow eg family :thumb:
By jayEGR
#213335 anyone iam pretty sure some one can give me some input iam just making sure before i buy it
By jayEGR
#213343 ls tranny srry from a b18a1
#213350 In an EG you can use any 90-01 B Series Axle.
Hoever if you go 90-93 you will need to use 90-93 axles or if you do 94-01 you will need to go with 94-01 axles if one goes bad. Reason being is on the driver side where the connects the two are reversed from what i have read. I have only personally used 94-01 Axles.
If your putting a Cable B Series Transmission in, You will have to get a hydro to cable conversion kit, any they never really work well.
I would HIGHLY recommend a Hydrolic B Series Transmission. If you want pure accerlation. the B16 Transmission is epic. shortest geared transmission honda makes and it is awesome, Biggest falling is freeway crusing. 70mph at 4k in 5th gear makes freeway crusing not pleasent.
The GSR Transmission is about 500rpms slower then the b16 transmission every gear. its better for freeway driving and still accerlates pretty good. Most people recommend this transmission for turbo applications.
Then the LS Transmission is good for getting good fuel economy and Long Cruises/Freeway driving. Some say this is best for boost, but their wrong. a GSR Transmission will make a faster turbo car then the LS transmission. These are normally the cheapest route to go though.
By jayEGR
#213354 thanks chrono but the tranny is hydraulic no cable, so i was wondering just use the a1 axle not the b1 because ive heard different things but just need the info before i buy them so i wont waste my money on my ls i already have the swap in but i trade my a/c lines for this cv axle but they were the rong ones and my friend is going to but them bak the cv axle i have are beefer meaning there five lug not four so they dnt fit the tranny or hub
By asianrob
#213411 actually it depends on your half shaft on which axles you need if you have the 90-93 half shaft you need 90-93 integra axles if you have 94+ you need 94+ axles.
90-93 are female ends and 94-01 are male ends.
hope that helps!
just trying to clarify
By jayEGR
#213464 good, just wondering if does but just needed to know also are any of them short ? and if this have problems meaning will it pop out of the tranny ? this are question i need to know but thanks asianrob ,now i know that but my mane question is the length is it short or not.
By jayEGR
#213527 nuthing just want to make sure its not to short ? :?
By asianrob
#213530 the should be equal length.
no axle shorter than the other...
By jayEGR
#213544 ok just making sure thanks bro :thumb:
By asianrob
#213599
jayEGR wrote:ok just making sure thanks bro :thumb:
:thumb:
