- Fri Jul 10, 2015 11:15 pm
#354622
I have a 93 EG8 Sedan and need to refill my freon. Does anyone know which type to use? I've seen people say r12 and others say r134. Can someone clear it up? Thanks guys
JohnRM wrote:Are you refilling because it recently went out, or it hasn't been working for awhile?
If first question, check to see if you have any leaks...usually o-rings. Afterwards, check your LOW side pressure port. R-134 uses a different sized port and will only fit that one. If it hasn't been converted and still has the
R-12 port, find a place to get it refilled. Hope that helps
-John
