- Sat Apr 11, 2009 8:32 am
#109856
well lads was wondering what mods you would have to have to make it safe to rev an eg9 to 9000 rpm, iv an aftermarket ecu in it so the vtec kicks at 5000 rpm and goes to 9500rpm. as far as i no the otrher mods are j's racing intake, full exhaust system (4branch decat the lot), full earthing kit, lsd gearbox. i dont no if it has standard cams or not i think it does. should it have upgraded pistons and cams to rev it this high.????????
If you want to rev it 9k+ and it actually do something you'll need a less restrictice intake manifold, a proper set of cams with stiffer springs and proper retainers and higher compression.
Otherwise you're just putting stress on the engine for no benefit.
