- Mon Mar 22, 2010 6:00 pm
#182889
if your asking what i think? using a cable trans in a hydro chassis, its nothing to it, hasport makes a kit to do it, and prob anyother mount company for that matter, it consisits a special mount, a bracket to hold your slave and thats bout it, you just have to drill you clutch ford and its a bracket with a heims joint type set up it uses all your stock hydro components... i have seen this kit on a car, have helpd install it in a car, it works wonderfully, (the actuall kit mounting was allready on the trans) if you wouldnt lift the hood to see it you would never know the difference the shift linkage and everything is the same tho this kit is designed to directly drop right in (you dont need to change anything!).... the only thing to watch for is using a hydro half shaft, you need a diff. seal as a hydro half shaft is a male style shaft and smaller around than the older cable shafts... we just went to the parts store and grabbed a random seal off the shelf and it was perfect but anyway... its been done, can be done and is nice because cable trans are cheap and easy to come by at least were i live... but they are not as strong as a hydro trans, the shift forks are pinned instead of welded, and the shifting mechanism is completely different...
hopefully this helps
http://hasport.com/store/index.php/moun ... egbcc.html
PANDA CREW No.20
