- Wed Mar 21, 2012 12:53 am
#299075
It could if it is not biting the flywheel like it is suppose to it will not engage your trans. When you press the clutch pedal down it forces the pressure plate to move the clutch disk away from the flywheel and allowing you to change gears. as you release the clutch pedal the clutch grabs back onto the flywheel and allows the car to continue moving.
Here this will help you understand how the trans work this is a d16 trans
http://youtu.be/vzYGcDZXgWQ
And here is the a honda clutch its very vegue but should help you to understand who it all works.
http://youtu.be/grp-virt7vI
- Wed Mar 21, 2012 5:12 pm
#299155
Long block is just a nick name for an assembled motor. Short block is a term for just the bare bottom end.
