- Thu Apr 10, 2008 1:07 am
#49859
LowTEC-Derbo wrote:i'm reading the helms and there is some things about shimming.. and specifics on this?
Shimming? The only things that might a "Shim" are these small washers that the Main input and counter shafts sit on. Looking at the book it seams as if thats what they are talking about.
In the book it talks about removing the "Oil guide plate" and the "Shim" around it, I never touched that when I was working on the transmission. so leaving it alone is probably a good idea.
When you first said Shims i was thinking about the type of shim where you put a piece of metal or wood in something to make it tight
I was thinking "What!?! No There are no Shims in there" Then I was thinking maybe he means those washers? then Looked at the book.
On those washers/shims I reused the ones that came in the transmission. I didn't mess with them.
