- Sat Apr 02, 2011 2:53 am
#247699
Well all hopes of running a b series went out the window today when I was reading the max attack rules... I have to run a block that came in the egs so that means im stuck with d series. So i'm lookin for a d series tranny with the shortest gears and also need an lsd!!! any input would help Thanks!!!
- Sat Apr 02, 2011 7:48 am
#247765
a hybrid gear set would be your best bet over aftermarket
- Tue Oct 04, 2011 3:14 am
#276089
Not in the US. We didnt get the B16 until the 99-00 Si.
edit: forgot about the VTEC del Sol. Hmm...that is still considered an EG chassis though, right? Sounds like a loophole to me.
kapow wrote:B16 came stock in the EG's, it's an SiR
- Tue Oct 11, 2011 4:27 pm
#277250
if the rules are the same/similar to our rules it does not matter were in the world X type of car came with X type of motor....like civic eg came with b16a2 then we can use that e.c.t
i would look into that better if i were u
rallyx_eg wrote:Well all hopes of running a b series went out the window today when I was reading the max attack rules... I have to run a block that came in the egs so that means im stuck with d series. So i'm lookin for a d series tranny with the shortest gears and also need an lsd!!! any input would help Thanks!!!
- Tue Oct 11, 2011 7:47 pm
#277280
Check junk yards/craigslist for a 92-95 EX coupe or Si hatch/del sol with the D16z6. These will have the shortest geared transmission.
- Fri Nov 18, 2011 9:36 pm
#281989
which class are you planning on competing in? which sanctioning body is the host of the event? I know for Rally America as long as the motor is made by the manufacture and it meets the requirements you can run it. I was just the Perryville rally a few weeks ago and a guy had a Suzuki Hayabusa motor in a Geo Metro and because the Metro was technically made by Suzuki and the motor was under the displcement cap it was allowed. I have also seen lots of hondas with b series swaps and even an h swap.
JUICE wrote:Race cars are like boats I guess. Time to bust out another thousand.
- Sat Nov 19, 2011 3:09 pm
#282053
pics now
D15kid wrote:which class are you planning on competing in? which sanctioning body is the host of the event? I know for Rally America as long as the motor is made by the manufacture and it meets the requirements you can run it. I was just the Perryville rally a few weeks ago and a guy had a Suzuki Hayabusa motor in a Geo Metro and because the Metro was technically made by Suzuki and the motor was under the displcement cap it was allowed. I have also seen lots of hondas with b series swaps and even an h swap.
pics now
