- Sun Dec 25, 2011 12:12 am
#286922
i made this from a ski doo tie rod end. Cut off the stud and drilled through the steel sphere. Then used a long threaded nut to dial in the throw. Cut the arm off and drilled a hole through it.
As for the mounting bracket i used a peice of an old brake pedal and straightened it out, drilled two holes and done some cutting. Anyway i just rigged up a mount for the frame rail. All in all it was a fairly easy conversion.
Great for someone looking to get by fer a few months till they can locate a hydro. Also the half shaft from a dc can be used just pair it with the dc seals or vice versa.
Here is two pics hope some can use this some day. Btw the gearbox is still working flawlessly in a 97-00 el with a b swap
